A1
| posted on 13/7/08 at 07:36 PM |
Alternator/electricity
Is it possible to use a standard R1 alternator and battery for an indy? i could see some weight advantages if you can...
| posted on 13/7/08 at 07:42 PM |
If you are using an R1 engine what else would you do? You could use a bigger battery but the generator and regulator is the only way to go
A1
| posted on 13/7/08 at 09:35 PM |
im sure i heard something about using a fiesta battery, but i was thinking that would be a waste...
cheers!
| posted on 14/7/08 at 09:02 AM |
It's not really worth using a bigger battery. After all the battery is only used to start the engine. From then on it's the alternator
that does the work...... Why use a huge battery that could spin over a fecking huge diesel when you've only got to spin over a tiny bike
engine???
