Bluemoon
| posted on 18/7/08 at 11:45 AM |
Progress pictures
Hi all,
About time I posted some picks of my take on an indy..
What do you think?
Dan
[Edited on 18/7/08 by Bluemoon]
Stuart_B
| posted on 18/7/08 at 11:48 AM |
it is looking good, what dash is that? is it a serria one?
stuart
t.j.
| posted on 18/7/08 at 11:54 AM |
good looking.
Do you have enough tread on the upper ball-joint sticking in you upper wishbone?
Mr Whippy
| posted on 18/7/08 at 12:30 PM |
very nice
100% convinced though that those headlamp supports will wobble and given about 2 months will snap due to fatigue
ash_hammond
| posted on 18/7/08 at 12:56 PM |
quote: Originally posted by Mr Whippy
very nice
.: www.mac1motorsports.co.uk | www.m1moc.com :.
Bluemoon
| posted on 18/7/08 at 12:57 PM |
Yep re headlights thought about that, will have a web welded on if this proves a problem.. But they are bigger than they look, 6mm thick by 70mm
strip..
Standard clocks.
tj. Yes they will be fine standard MK part. They are not setup yet so not adjusted correctly.
Dan
eccsmk
| posted on 18/7/08 at 02:03 PM |
i like that alot
well done
now if you could just pop round and finish mine
Mr Whippy
| posted on 18/7/08 at 02:51 PM |
strip..
Standard clocks.
Dan
On my Falcon I fitted two lights to the front apron (5mm Aluminium) with large spreader washers, about a month later they fell off after cutting two
large neat holes through the metal...
worX
| posted on 18/7/08 at 03:15 PM |
Looking good...
Mave
| posted on 18/7/08 at 05:04 PM |
Looking good. Could you explain how you made the bonnet? Look really nice.
And is that a Mangroveworkshop-screen?
Bluemoon
| posted on 18/7/08 at 07:47 PM |
Bonnet was made by carefully bending it around a bit of 38mm tube. I first mad a template from lining paper, then cut the ali a bit over size. I
couldn't find a bit of tube the correct diameter, to I simply ran the sheet backwards and forwards with a little hand pressure to gently bend to
panel. Take ages you need to keep checking again the nose and schuttle. Also the bend radius is different at each end..
This takes an age, as you need to do it bit by bit it's so slow you wonder if your actually bending it! Took about a day to get the shape. Then
I bent the ends over into an L with a rubber malt and a couple of wooden batons as per the book.
Bluemoon
| posted on 18/7/08 at 07:49 PM |
It's a Westfield screen (can't remember which one though at the moment).
Dan
Bluemoon
| posted on 18/7/08 at 07:50 PM |
Mr whippy,
Which bit failed the 5mm plate or the thing it was attached to?
Dan
