Stuart_B
| posted on 19/7/08 at 09:05 AM |
The back panel
hi all, how do you put the back panel on?
thanks
stuart
TOO BADD
| posted on 19/7/08 at 09:17 AM |
Tiger Seal from Gramics in Magdelen St Colchester.
afj
| posted on 19/7/08 at 12:17 PM |
fit it using some clamps , do some chopping and fileing until it looks ok, then i used 3 large head rivets and pu down the angled parts of the chassis
which go down from roll bar ,back then a little pu along the bottom round chassis rail. once the rivets squeeze the panel in it fits ok
graememk
| posted on 19/7/08 at 01:38 PM |
i got mine to fit, (which is hard on a indy lol) pu on all the inside bits, pu on the square tube behind the arches and a couple of rivits on the
square tube either side.
then went under th indy and added extra pu to the round tube at the bottom and smothed it out and pressed it in to get rid of water traps.
i also pu'ed onto the fuel tank to stop vibrations
[Edited on 19/7/08 by graememk]
Stuart_B
| posted on 19/7/08 at 03:10 PM |
i got the tiger seal, what is a normally price per tube of the stuff?
as well has any body got some picyures what it is ment to llok like and how they got there?
thanks
stuart
