New Topic New Reply
Author: Subject: Semi - synthetic engine oil 4 diff
westindy
posted on 5/1/04 at 07:28 PM Reply With Quote
Anybody tried using engine oil in the Sierra diff to reduce friction for a BEC car - that ep90 is like treacle!!!
posted on 5/1/04 at 09:26 PM Reply With Quote
Depends...
...on whether the diff. is a slip diff or not. If it is LSD IMHO I wouldn't use anything other than recommended oil.
posted on 6/1/04 at 12:50 PM Reply With Quote
Do bear in mind however, that diff will not be doing as much hard work in a BEC. Would still use recommended oil though. HTH
timf
posted on 6/1/04 at 01:01 PM Reply With Quote
the gear oil is heavy to resist the pressures that the gears meshing
together generate if you use engine oil the diff will be fubar very quickly
New Topic New Reply
