A1
| posted on 17/9/08 at 01:04 PM |
throttle cable for r1
what throttle cable should i use? the r1 ones a wee bitty too short, would a sierra one do?
cheers
Paul TigerB6
| posted on 17/9/08 at 01:09 PM |
Have you considered using a push bike brake cable?? Cheap and readily available.
locoboy
| posted on 17/9/08 at 01:14 PM |
I used pushbike brake cable bought by the meter with the outer and somr fittings for both my throttle and return.
Cost about a fiver in all.
Locoboy
A1
| posted on 17/9/08 at 02:12 PM |
is it necessary to have a return cable?
cheers
Paul TigerB6
| posted on 17/9/08 at 02:15 PM |
The throttle mechanism is spring loaded but extremely light so you will want to fit a return spring to your pedal but you wont need a return cable
