New Topic New Reply
Author: Subject: Trouble fitting rear Diff
peteday_uk@btinternet.com
posted on 6/10/08 at 01:47 PM Reply With Quote
I know that this question has already been answered on here, but I have tried looking and can't find the answer.
I have tried fitting the diff to my indy r chassis and after first finding I had a 7.5" diff (bummer), I have now got a 7" diff but can't seem to fit the bottom m12 threaded bar because the chassis is getting in the way. Any ideas?
posted on 6/10/08 at 01:52 PM Reply With Quote
Which bottom bolts are you trying to fit?
On the Indy chasis (not sure if it's the same on the R type chasis) you only fit the upper bolt and lower rear bolt. the lower front bolts are not fitted.
Hope that helps!
posted on 6/10/08 at 01:57 PM Reply With Quote
I didn't know there were front bolts on the diff, but if the bolts were in the diff would be be in the correct position. So without looking (work) at the diff i'm sure it's the rear one i'm trying to fit.
eznfrank
posted on 6/10/08 at 02:34 PM Reply With Quote
i think, without looking (also at work), that when i did mine i used threaded bar for the top mount and 2 m12 allen cap bolts with the nut on the outside ie. The bolts inserted facing outwards if that makes sense?
posted on 6/10/08 at 02:41 PM Reply With Quote
makes perfect sense, I think.... will have a look and go when I get home tonight. Thankyou.
martyn_16v
posted on 6/10/08 at 03:40 PM Reply With Quote
What eznfrank said, use cap head bolts instead of the long rod.
Stuart_B
posted on 6/10/08 at 03:56 PM Reply With Quote
i put the two long orginal bolts, by putting the bottom one in first and then the top one in.
two hands and handing for this.
stuart
Mark G
posted on 6/10/08 at 06:01 PM Reply With Quote
I managed to get both of the long bolts in and then realised after that it says in the manual to use alan key headed bolts for the top because the long one is a struggle to fit.
Bluemoon
posted on 7/10/08 at 07:36 AM Reply With Quote
I used two hex head bolts modified to fit in casting so as not to turn (ground some head off load bearing surface did'nt need modifying so bolt is more than strong enough. I could not get the allan key to fit as chassis was in the way.. Tried the long bolt approach, could'nt get that in place either..
Mind you back when doing this diff is heavy could have done with two people!
Also you should pack out any space between diff and frame with washers/shims so as not to bend plates that hold diff when you do the bolts up..
Dan
[Edited on 7/10/08 by Bluemoon]
eddbaz
posted on 7/10/08 at 06:41 PM Reply With Quote
I did mine the same as Dan explained above.
posted on 7/10/08 at 08:45 PM Reply With Quote
I have ordered the bolts and should be fitting tomorrow. Should be ok. I'll let all know tomorrow.
Thanks for everyone's help.
posted on 8/10/08 at 11:14 AM Reply With Quote
Fixed and secure. Used two m12 x 50mm allen head bolts.
Thank you to everyone who posted. Much appreciated.
Pete.
New Topic New Reply
