indyian
| posted on 18/10/08 at 12:22 PM |
do you need bonnet bulge to fit zetec into indy
as above do i need to get a bonnet bulge for my indy if i want to fit 2.0 zetec or will it fit without many thanks ian
whitestu
| posted on 18/10/08 at 12:32 PM |
Not needed - My 2.0 blacktop fits fine.
Stu
MikeR
| posted on 18/10/08 at 01:05 PM |
Stu - how have you got your sump set up (standard or cut down) and how much ground clearance do you have ?
bob
| posted on 18/10/08 at 03:40 PM |
You can get away with it no problem although i like the bulge and a cheap bonnet came my way
MikeR
| posted on 18/10/08 at 04:16 PM |
but what ground clearance have you got?
bob
| posted on 18/10/08 at 04:50 PM |
With the 1800 sump i had 72mm, i now have the tiger ERA sump which makes the bellhouse the lowest point.
I will have a measure tomorow and get back to you
whitestu
| posted on 18/10/08 at 07:03 PM |
I chopped my blacktop sump to give about 75mm of clearance. I've driven it quite a bit & over loads of speed bumps with no grounding
problems.
Stu
bob
| posted on 19/10/08 at 01:13 PM |
With new tiger ERA sump the ground clearance is now 135mm with the bellhouse being the lowest point at 110mm.
The 1800 sump i used previous didnt cause any problems with regular speed humps, i had to be a bit carefull with the humps that are placed in the
centre of the road though.
As you can see from earlier picture the new sump does make a lot of difference and makes other objects often found on the road less
worrying.
indyian
| posted on 20/10/08 at 04:37 PM |
thats cheered me up i thought i had to get new bonnit thanks for all the replies guys
