New Topic New Reply
Author: Subject: clutch pedal
A1
posted on 4/11/08 at 09:47 PM Reply With Quote
clutch pedal
does anyone have any photos of what theyve done here? was wanting to see what people had done....
its an r1 clutch cable on a r chassis.
cheers!
skydivepaul
posted on 6/11/08 at 02:31 PM Reply With Quote
use the R1 clutch cable, standard fit on the engine.
I modifed an old clutch cable and used the steel sleeve to run through the bulkhead. crimped the R1 clutch cable to it.
drilled the clutch pedal botom hole out to 8mm.
drilled a 2mm hol through an 8mm bolt to clamp the cable through. bit crude but works a treat.
i will post a picture today
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
New Topic New Reply
