Finally got one :)
parkiboy - 20/5/12 at 03:26 PM
Been on the market for an MK for a while now and i'm finally getting one on tuesday!
Its an MK Indy R with a hayabusa engine, with the following spec:
hole shot racing baffled race sump
sierra 4x4 limited slip dif with correct gearing (3.14)
GAZ shocks and coil over dampers
Disks all round
Willwood brakes
R888 toyo tyres
MK electric reverse
MK cable gear change system
MK clutch system
It's pretty much a new build, it was built by a syndicate of people planning on using it for track days but it only saw one practice session as 2 of the builders moved away, looks a high quality build and the electrics have been done professionally by an auto electrician, the problem with this is it is not IVA'd yet so thats the first job on my list!
big_l - 20/5/12 at 03:33 PM
Congrats mate. !!
Just check the diff the rare 3.14 was only fitted to diesels !!
Sierra 4x4 had 3.62 wich will give you a really low top speed
Just worth a look ..
parkiboy - 20/5/12 at 03:37 PM
is it possible that they changed the gearing? But no problem i will get it checked out thanks for the heads up!
big_l - 20/5/12 at 03:40 PM
The 3.14 came in a 7inch diff the LSD 4x4 diffs were 7.5 inch with bolt on driveshafts ..
You got a link to the advert ?
parkiboy - 20/5/12 at 03:43 PM
no i havent it was on ebay but we came to a deal off ebay so it has been taken down.
tomgregory2000 - 20/5/12 at 03:46 PM
Wrong, LSD 4x4 2l is a 7" unit with bolt on shafts
I believe you can swap the crown wheel and pinion from one diff to another
big_l - 20/5/12 at 03:46 PM
Ok cool I'm sure it's fine just bear in mind that the 3.14 diffs are £500 + to find
And 3.62 LSD is about £200 max
Either way I'm sure you will have a blast !!!
parkiboy - 20/5/12 at 04:01 PM
apparently because it was built between 4 people they were able to throw alot of cash at it so its probably right then, 2 of the guys never actually got to drive the car lol
fesycresy - 20/5/12 at 04:19 PM
3.14 LSD is just a 3.62 LSD with 3.14 CWP.
You 'may' have a Quaife ATB or similar if they threw loads of money at it?
austin man - 20/5/12 at 05:00 PM
Make sure you get all build photos and receipts otherwise you will have a nightmare getting it through the IVA
mad-butcher - 21/5/12 at 10:22 AM
I suppose really "correct gearing" is a matter of personal choice, do you want top end or quick get away, I've got a 3.62 in my Blade and more than happy, leaves most things for dead at lights and gives a fair account for itself topend wise, plenty fast enough to get me banned, just my humble opinion.
tony
Custardpants - 22/5/12 at 07:30 PM
Your Indy with the buss and 195/50/15s will just nudge 120 before the limiter if it's anything like mine, using the 3.62 diff. Planning on going for 205/60/15 rears for tracks like donington and Bedford, which will give 130mph.
mark chandler - 22/5/12 at 08:49 PM
My car has a 3.14 LSD, I made it up from two diffs, shoving the CWP from the diesel diff into a 4x4 LSD unit, easy to do
Even then it tops out on the brands Indy circuit as you reach the pits
[Edited on 22/5/12 by mark chandler]
parkiboy - 12/6/12 at 04:53 PM
I've finally got some pictures of the car, since buying it i have redone the interior as it was shameful to be honest, i have also relocated the indicators to the wings, wired a car horn, wired the rear fog light and relocated the reverse switch as it was right next to the gearstick where you rest your arm, stupid place!
I've going to send off all the IVA paperwork in the next couple of days the only thing left to do before then is just a bit of radius i think but if anyone spots anything major please let me know
Pezza - 12/6/12 at 05:16 PM
Better check the front indicators are within the minimum distance from the outside edge of the vehicle.
We put ours on stalks for the IVA.
Also check your foglight lens is vertical (90 degree to road)
Our tester was very keen on sharp edges, if in doubt trim it.
[Edited on 12-6-12 by Pezza]
Macbeast - 12/6/12 at 05:30 PM
I should put a bit of rubber edging on your front cycle wings.
imp paul - 12/6/12 at 05:43 PM
it looks really nice happy days and lots of fun
parkiboy - 12/6/12 at 06:08 PM
thanks for the tips guys, is there any reason why the fog light has to be 90 degree from the road and the others do not? i might have to buy a cheap 90 degree fog just for the IVA.
Can i ask how you did the stalk extensions? can you actually buy these or was they fabricated yourself?
Thanks for all the tips guys any help is greatly appreciated as im picking up the last few bits up at newark on sunday hopefully!
I am also aware that the steering wheel wont pass but MK are letting me use one of there sierra wheels for the test.
thanks
Pezza - 13/6/12 at 05:47 PM
Stalk extensions was an ali tube all the way through the nose cone so as to stop droop or bouncing.
parkiboy - 17/6/12 at 08:04 PM
IVA paperwork all filled in and the last few little bits are ordered - getting excited now
handyandy - 17/6/12 at 08:19 PM
Nice car
No need to buy a new fog light , if you buy a small length of waste tube from screwfix that matches the diameter of the fog light you already have ( think its 95mm dia ) & make a wedge shape at an angle ( Haynes Roadster is 14 degree,s IIRC) that matches your rear tub to ensure the fog light is at 90 degrees to the road , its easy enough to glue your current light into the waste tube & screw to the rear tub ...hope that makes sense
I have the same lights & here,s a pic showing the fog light ,
hope it helps, & good luck for the test .
cheers
andy
parkiboy - 17/6/12 at 08:30 PM
that looks great, does the reverse lamp need to be like that too or have you just done it to match the fog? did you just but the light in the tube or glue the hole light patress/plinth in?
parkiboy - 17/6/12 at 08:34 PM
can i ask aswell, i am yet to put a grill in the nosecone, someone at newark today told me the mesh fails IVA and you have to put something over it?
can anyone shed any light on this?
handyandy - 17/6/12 at 08:37 PM
Thanks ( I must confess...the idea of the tube was from another forum member)
The waste tube cost me £1.89 from screwfix
The reverse light doesn,t need to be at 90 degrees but I did mine just to keep a "uniform" look,
I glued the original lense mounting plinth inside the waste tube as this then allows you to use the original plinth to use bolts/nuts and mount it to the rear tub ,
I used some small rubber trim where the tube sits against the tub as it creates a snug & tidy fit .
cheers
andy
Custardpants - 18/6/12 at 10:45 PM
Is it just me or is your coolant plumbing not quite right. Your bottom expansion tank line should be t'ed into your bottom hose to keep your pump primed, not your top one. Also your 8mm line coming from your wateroutlet under your carbs should go to your top
Line too, certainly not your expansion tank? I stand to be corrected though...
parkiboy - 19/6/12 at 08:34 PM
Is it really?? Can anyone confirm this? I'll have to get it checked out!
The guy did say he did have overheating problems on idle but was fine when moving
maccmike - 19/6/12 at 09:00 PM
its a beauty that mate
