Just had my first blat as a fully road legal car. (Got her registered on Friday.) What a hoot!
Car drove impeccably. Engine ran sweet as a nut and what a howl when she hits the powerband at plus 7k revs - she takes off like a scolded cat!
Had the back end step out a couple of times on roundabouts but was quite easy to catch it and pull back into line. (Mind you, I reckon it'd be a
totally different story in the wet!)
Clutch is going to take a little getting used to. I stalled it once but then tended to over-compensate and induce lots of clutch slip when pulling
away. Think I'll have to fit a stronger return spring to accelerator pedal to make it less sensitive.
There were no horrible rattles/squeaks etc. coming from suspension etc. So all in all, a pretty good shake down run.
Think I'll go out again in a minute (its only right to take advantage of the sunny weather while it lasts!)
Great feeling isn't it. Take it easy out there. These cars can bite you in the arse with little warning. You don't want to have to start
again.
adrian
wheeeeyyyyy! Great news! is it as good as you hoped it would be?
Good news
Great feeling
All though I bought mine driving it back was the most fun ever in a car 3 hours of grins and backing sunsine to boot.
Have fun and keep safe
As you said it's great to drive something that was build by yourself.
Building an Avon is a pain in the ***, but when they're finished, they handle and drive very well.
I find them underestimated...
