Hi all
A mate of mine has a Avon wire loom to fit in his car has anyone had any probelems with this type of loom
He is removing the wires for the heater / windscreen wipers
Jacko
its not the best loom and needs some aditional wires fitted for brake fluid switch and something else i cant remember. i ended up adding a couple more
relays and making my own engine loom
it's also very long in some areas so you end up with coils of excess loom.
have a look at my website and you will find the wiring diagrams, spreadheet and some other bits...
HTH
i used one for my indy,i still have the wire insuctions if you need a copy
Also... I have heard tell that Tiger sometimes chnage the wire colours if they dont have the right colour available... that wasnt the case for me and
mine matched up with the coulor guide spreadsheet on my website....
if you label every wire (takes a long time!!) then see what your left puzzling over we may be able to help out...
cheers
Thanks for the help so far
Jacko
