Hi all
I've finally got around to stripping the interior and in the process adding a tiger gearbox remote extende to the avon. All seems to be ok,
however it now seems very hard to get into reverse and 5th gear. when I say stiff it gone from smooth as silk to a proper gym workout getting reverse
and a grit your teeth fight to get it into 5th. 1st, 2nd, 3rd and 4th are fine.
Is this normal and to be expected , appreciate its not likely to improve the link, I've thrown on loads of grease but it doesnt seem to make a
difference?
Any ideas?
Fitted the Tiger remote to my S6 - not the finest piece of engineering.
I needed to quite a bit of adjustment to get it just right - this included opening up some of the mounting holes IIRC. Overall shouldn't be tight
on the gear selections.
I'd say loosen the three mounting bolts and try a few different positions to see if it improves.
Steady!
I needed to quite a bit of adjustment to get it just right - this included opening up some of the mounting holes IIRC. Overall shouldn't be tight on the gear selections.
) GTS Tuning. Ok thanks all - well first I will try the alignment, then if not its going back to tiger..
*If* its similar to the Westfied one sometimes it's necessary to put either one or two plain washers under the monting holes
This seems to sort any alignment issues
