Hi guys
Can anyone tell me what kind of torgue settings people of used for the front ball joints for the suspension and the track rod ends.
Has everyone fitted the split pin in the upper ball joint as per tigers book?
Rob
the split pin is only needed if no thread comes through the nyloc on the nut.
i had the nut machined thinner so that the threads came through the nylon insert.
