I have just bought a new pair of headlamps for my Tiger Avon,unfortunately the previous owner removed the old lamps & all i am left with is the four wires.I dont have a wiring diagram so dont have a clue which wires to connect to new lamps.Can anyone help?
Use a volt meter?
Is it a sierra loom?
Iirc mines
Grey black to side light
White to dipped beam
Yellow to full beam
Brown common earth.
Can double check at about 4 pm if need me to n
Not sure if it is sierra loom,i have no history or manuals with the car,thank you very much for your help.
Test each of the wires with a ohmmeter and find the earth connection, by testing between chassis and each wire in turn.
Mark the one that connects to earth.
Make sure no wires are touching earth and put side lights on you should see a voltage on one of the wires 12V when tested between itself and earth
with a volt meter. That will be the side light wire.
Do the same for main beam and dipped beam label them as you go, its a process of elimination
Originally posted by big-vee-twinDo the same for main beam and dipped beam label them as you go, its a process of elimination
Yes I was tempted to put illumination
GR indicator
UR dip beam
UW main beam
R side light
B earth
UR dip beam
UW main beam
GW indicator
R side light
B earth
Hoper this helps. UR is Blue red, UW is blue white R is red B is earth. GR Green Red.
Thye left and right sides ahve different colours to distibguish them on the loom. Hope this helps
Ian
Thanks,i have fitted lamps & they work ! i did not have any fires or melted wiring thanks to the help i recieved on here.I am very impressed with the great people on this forum.
