Hello,
Whats the score regarding the mounting of the headlamps? I have seen some people mention fitting spacers to elevate them higher. Then again, I have
seen some fitted directly to the chassis mounts?
Is it an SVA requirement to raise them up?
Ta
This is from the draft copy of the latest SVA manual but is has'nt changed in the issued version.
Its been mentioned here several times before but its well worth getting a copy of the latest SVA manual.
Thanks v much,
Yes I will make sure I get a copy of the SVA manual.
Had to raise the mounting points of the lamps about 50mm above the top chassis rail to get the required 45degree angles of visability req'd by
SVA.
Mount them lower and the nosecone blocks the 45 degree view. - Alan
Jack up the suspension for SVA. It helps with the minimum height of all the lights
I did exactly what Northy did , jack up suspension. I drilled the indicators a tad too low and couldn't be arsed to move them.
