What length are the standard tiger Avon coil overs? It not mentioned in the book I'm looking to set up my brackets
[Edited on 30/5/15 by locost7-online.com]
Bump
I'm looking at setting up my wishbones do want to make some solid brace bars to hold it all at correct distances
Does it not tell you in the back of the book? If not give tiger a call.
You may determine lengths by measuring available space and desired suspension travel.
The longer remember that for each inch of extra travel you'll have two inches of shock length.
HTH
