Hi All
Just before i weld up the front tunnel tubes and cut away the lower rail, can somebody please measure the distance from the side rails.
In the book these are different lengths, is this correct or a print error?
One side is 252-3mm and the other is 275mm, this is how i have done mine but i would like to know if it's correct before i weld them in for
good.
Regards
Nik
If I understand you right. I can confirm that the two footwells are different sizes. This is because the engine and gearbox is slightly offcentre.
Carl
Mine's buried in the garage so can't get to it to easure, but if you're fitting a Pinto, the alternator will probably hit the front
brake pipe that goes down the rear front suspension bar.
Pat...
it looks like its in same place as mine and it just misses it if your locky but i could be never close
Pat I don't think thats his chassis I think that belongs to ayoungman from Erith kent
Carl
Glad to here that the footwells are different, sounds like it's not a print error then.
Will be running a 2lt zetec if that helps.
It's not my Chassis i used the picture as it shows the tunnel tubes.
Yep, thats mine, its a Tiger bought chassis number 100. The two footwells are slightly different in width.
I was down your way the other week I had to go to Slade Green Railway yard to look at some access equipment that South East Trains have got. Next time
I will drop you a U2U. Are you far from there?
Carl
I'm only 5 minutes drive up the hill from there !. Your also only 5 minutes from Caterhams assembly workshop. Let me know next time. pop in fro a
cuppa !
