Whats the average sump/floor ground
clearance most of you are building/built to ?
or rather sump below chassic rails
Enough to clear a house brick or are you all rabbit friendly !
Our sump is approximately 25mm below chassis rails. We ran the blade about the same with little problems negotiaing speed humps (sleeping policemen). Not that they sleep - they only break speed limits now...
