can anyone help me on this. My indicators have stopped. I a have mk indy with R1 engine just about ready for SVA but indicators have stopped flashing..when i press hazard switch the switch lights up and just stays on.. I did not build the car so i am looking in dark really, but one of relays looks like it has got really hot and damaged outer casing. i have chescked fuses, and they were working before.. any ideas.. can i check relays ? thanks for help...
Sounds like the relay to me, if the light is on constantly... and it gets hot and looks damaged.
def sounds like the relay, they are quite cheap, should be able to get one from your local motor factors
been quoted £25 from ford.. any
other ideas
Even Halfrauds only charge £5
