Hi all, very quick on are the rear hubs on the Avon handed? and whats the difference.
I'm fairly sure that the answer is yes, however i swapped mine around, as others have done, to fit discs braked rear and it seems to be fine.
Mac
I've been look through the book and its seems that there is a offset of 10mm from the vertical on the drawings.
Now the drawing in the book is for the N/S with the 10mm to the rear of the car, so if I fabricate two identical hub carriers the O/S will have the
offset to the front of the car??
I have heard of swoping calipers so the flexi does'nt foul the wishbones?
