any ideas how much a roll bar is from Tiger? thanks.
Try this?
http://www.tigerracing.com/ALC_parts_aug06.pdf
I vaguely remember the simple hoops being about £60 plus VAT ... but it probably depends on the type of Tiger, and finish required. If you want the
properly braced job (and you should) then I suspect its a lot more expensive.
Best to call Sue on 01733 271131 and ask.
Richard
Hi I have a pair of Tiger B6 roll hoops if they are any good to you,, 50 quid????
Regards Kipper.
thanks for getting back to me. Im building a Tiger Avon and I want the pair of roll bars rather then the one big roll bar.
i'll check if Tiger B6 will fit the avon and get back to you. mite have to wait until tuesday tho before I can check with sue whether it will
fit, thanks. i'll let you know asap.
if it does fit then i'll probably follow you up on that offer (kipper).
