Hi Mate,
With regards to your body - how much of the inside lip did you need to trim off that is supposed to clip over the round bar of the chassis that you
climb over?
Pat (www.mytigeravon.co.uk)
well wether this is right or wrong i haven't a clue because the tub is wider than the chassis and the bits you mention are narrower than the
tube.
i cut mine down to about 2 inches and had to run a powerfile up the inside to remove excessive resin etc, then heated them with a heat gun to help
them flex a bit...
not happy with the result but then why should i be, i am tempted to scrap the tub and make my own from alli....can't look any worse even if i do
it while i am drunk and blindfolded...
