OK guys,what wheel offsets can be fitted onto an Avon ? Sierra is ET38, but what have other people used and what effect has it had? Help needed on
this one, since I'm a complete NUMPTY when it comes to this sort of thing
ATS wheels with ET 35, I find they look great.
See the result in my photo archive under "ATS".
But this my personal opninion, I've tried wheels with a lesser ET and they came out of the wheel arches.
cheers JP
HI had a look at your pics the wheels look nice and they are not that expensive either, i need some wheels soon as the ones i had would have rubbed
the arch under load ,also are they westfield racing seats you are using? if so join the club how did you fix them in, i ended up moding the bases to
get them to sit lower then side mounting them.
not exactly a answer, but take a look here:
http://www.carbibles.com/tyre_bible.html
and here for going from one wheel width/offset to another
http://www.1010tires.com/WheelOffsetCalculator.asp
Originally posted by soggy 3
HI had a look at your pics the wheels look nice and they are not that expensive either, i need some wheels soon as the ones i had would have rubbed the arch under load ,also are they westfield racing seats you are using? if so join the club how did you fix them in, i ended up moding the bases to get them to sit lower then side mounting them.![]()
I will take some pic of how i fitted mine in.
That offset calculator is good i would have brought the wrong ones!
