Has anyone fitted a megasquirt v2 (ie to control ignition and injection, not v1 that only sontrols fuel) to a 2.0L zetec with jenvy throttle bodys? If so could you email me a map to get me going. Also any advice would be appreciated.... cheers in advance, jamie.
They will all do fuel and ignition, you just need to run the 'extra' firmware and use an EDIS module (from an Escort mk5 or Fiesta mk3) to
run the coils.
Chris
ok i see what u mean, but i really could do with a map to get started
Megasquirt maps
Google is your friend!
As u2u try tim windmill
