Has anyone fitted a balance bar and master cylinders from OPB? If so what did you do for a brake fluid level sensor - as far as i can tell their reservoir doesn't contain a float switch....
can't really see how you can detect fluid level without a sensor; maybe some sort of sensor in the pressure line?
no u need a float switch in the reservoir for the sva.... just wondered what other people used....
Check out the rally design site or Car builder solutions who do a separate switch .
I am using willwood mastercylinders and if i remember corectly i did a search and i found out mk 5 escort mastercylinder tops fitted, so i went down
the scrappy, job sorted.
[Edited on 27/3/08 by soggy 3]
Oh and when your in the garage next put that tiger book in the bin.
I used a Sierra cap on my master cylinder.
One of these on ebay...?
260117638362 - Ford brake res cap
I've got Girling master cylinders and these fit perfectly
Pete
i got one from carbuildersolutions.co.uk fitted perfectly and had a test switch built in......
cheers everyone
