Hello,
Can everybody that finisched there car give me an idee from the total weight.
If possible corner weight
i dont know whether you managed to answer your own question by now or if this information is of any use to you now but ive just got my vin plate from
tiger and on it is the axel weights and they are as follows:- axle 1= 450kg axle2=500kg
total weight 950kg .this is using a 2ltr pinto engine and a fairly standard set up.hope this is of help to somebody.
950Kg !!!!!
is that with the optional lead filled chassis ?
I'd guess that they are the axle load figures that would be declared in the SVA.
I'd expect the average Locost to be around 600-650kg (and don't bother to tell me that yours is lighter!)
Of course mines lighter - its just a bare chassis with nothing attached yet...
Thanks for the replay's.
I wanted to now the excact weight from an AVON with different engine's.
I supose somewere between 600 and 650
But was hoping that Avon builders that finisched there car had weight figures.
AvonBelgium
