Hi all.
In relation to Davey D's 'Self Centering' topic, there was a lot of talk about tyre pressures.
What are the recommended tyre pressures for a locost 7 type?
I am running mine at 16psi all round.
Running 18psi all round on mine
18 psi will be ok if the tyre is a 195 size
i run 15 all round but think this is a bit low so im going to put mine up to 18-20 psi
They are 195/50-15's
18psi works for me.
I run 18 psi all round (195/50 15's on a 685 kg Fury)
mnr vortx on 195 /205 rear 161b runs great
Just as a thought is there any kind of formula to work it out? Sometimes my tintop tyres look low but then when I check them they're exactly at the pressure the book says
I always thought that they were higher at the bottom because that's the bit being squashed so there's more pressure.
I make sure it's in the middle so I get an average
