Does any one know the Aldi Air Tool male coupling type that screws into the airtool so it can be connected to the female coupling on the Aldi air line? I've called the PowerCraft help line and even they do not know! I think it may be a CEJN fitting possibly 130/25 at a guess but I'm not sure. I also need to know what the male screw thread size/type is that screws it into the airtool. Anyone know the spec so I can order some?
usually a 1/4" thread. any photos of the coupling? i only know of 2 types, most common is the PCL type
like this
http://www.pclairtechnology.com/Products/Product?ProductId=9
[Edited on 22/12/10 by blakep82]
Standard air tool fittings are supplied by the likes of Machine Mart. I imagine its going to be something like a 1/4" BSP fitting. At least thats what all our air tools at work take.
the common type in this country is pcl (the loong narrow one)
the other has a few names but pcl xf should find it, its short and wide, that what most airtools come with in the box and ive found them to have a
better air flow.
I think from memory the Aldi ones have the same as these on the bay Item number: 280562868992
