Quick question....
How do you get the tail lights to stay on when you switch from sides to headlights?
I tried to feed 12v to the tail lights from the headlight switch, but when you switch to sides the front headlights stay on rather than just the
sides....
If your building the car for the race series, you don't need headlights
Your side lights should be on all the time the lights are on. Your sides shouldnt be turning off until its switched to off..
Sounds like your switch is just a plain 3 way switch.
[Edited on 24/12/12 by Ben_Copeland]
I will check the switch, which is from a VW polo (it has quite a few spare terminals)
