Hello all.
I’m after a bit of advice please.
While out today in my Westfield 2012 it came to a grinding halt.
Luckily I was only doing about 20MPH. I coasted to the side of the road put my hazards on but not even they had any power. I lifted the bonnet and
found that the main fuse (maxi 60 amp) located on the chassis rail had blown.
I’ve taken a quick look around all of the wiring within the engine bay and can’t see anything obvious.
Ideally I need a wiring diagram for a 2012 Westfield to see what is powered where to try and trace a possible cause for the fuse blowing.
Any advice/ways to test for a possible cause would be a great help please.
Thank you. Martin.
Can't help with a wiring diagram but I´d start with high powered stuff like lights and heater blower if you were using them, which I would have thought you were today!
Lights yes, Blower No. Wouldn't the small fuses that deal with the lights blow first?
[Edited on 8/4/18 by piddy]
Yes, if it simply a load line fault then if the light eg are fused separately then that fuse should blow.
But , and this is why you need to do some checks You could have a flat before the fuse, or the fuse been replaced by a nail!, or the main fuse be
weak.
Start with a resistance check to.earth on the blown fuse line with the battery disconnected. To see if there is an obvious issue
Look over the wiring too in case something is chafing to the chassis or similar
In the absence of a wiring diagram you need to trace where the feed from that 60A fuse goes, shouldn't be too difficult as it will presumably be
fairly hefty cable going from it. It will probably feed main fuses, starter relay & alternator. Anything the other side of fuses would blow the
low amp fuse first.
Most likely would be a short on the main feed to the alternator.
Have you tried replacing the fuse, or if you just touch a thin cable across it momentarily (be careful if shorted it will burn out very quickly - you
don't want to be holding it if it did! - it only needs a momentary touch to see if pulling big current) is it still drawing current?
Agree with above, alternator feed seems the obvious place to start. I had an alternator self-destruct and internally short, melted the wiring loom and
caused a small engine fire. I say me, it was the missus driving our herald at the time, with both small kids in the back. Bit scary.
I digress, basic fault-finding should get it sorted.
Thanks all for the advice.
I'm now off to work so I will update you on what I have done and found so far, later when I get home.
