Rubber Grommet / Isolating bush correct name?
r1_pete - 29/2/12 at 09:44 AM
I need some rubber grommets, the type which puch into a hole in a panel, take a crush tube and large washers, and are used to isolate components from vibration, usually used with M5 / M6 screws.
Can anyone tell me the correct name so I know what I'm asking for?
Cheers.
Pete.
loggyboy - 29/2/12 at 09:53 AM
Cotton reel?
http://www.cbsonline.co.uk/product/Cotton_Reel_Rubber_Mount_20mm_Dia_x_15mm_COT1
owelly - 29/2/12 at 10:00 AM
Like these?
http://item.mobileweb.ebay.co.uk/viewitem?itemId=220938941824&index=4&nav=SEARCH&nid=09545343578
Mopple - 29/2/12 at 10:33 AM
Maybe "bobbins" is the word to look for.
melly-g - 29/2/12 at 10:35 AM
Look up memfast and they have things called rubber nut, are they what you mean?
gremlin1234 - 29/2/12 at 10:58 AM
are these what you mean?
http://merlinmotorsport.co.uk/product_info.php?products_id=13790
M6 FEMALE ANTI VIBRATION MOUNT (PACK OF 10)
Rubber anti-vibration nuts for mounting electrical components, dash panels and oil coolers. A rubber nut with EPDM body and a brass insert. Drill the hole; insert the rubber nut: insert screw and tighten;
daviep - 29/2/12 at 11:10 AM
I think it's something that looks like this you are after Description
Have a look HERE
Also search for "ring and bush mount"
Davie
skov - 29/2/12 at 01:05 PM
There's various things here that might suit:
http://www.antivibrationmethods.com
r1_pete - 29/2/12 at 09:16 PM
Thanks for all the leads chaps, I should get sorted now.
