Hey folks, hope someone can help.
I've had my car off the road for about three weeks now to change the oil, clutch, springs and mod the clutch slave cylinder push rod (it was
miles too long!). So its all back together now and wont start!
When you turn the key everything sounds normal, the dash lights up, the fuel pump primes but when the engine turns over it just wont fire. I checked
the plugs and they are getting fuel (they were soaked when I took them out) I also get the F1 light flashing after a few seconds of it trying to
start
Are these engines very specific when it comes to the voltage required (battery could be a bit flat) to provide a spark?
I haven't touched any of the electrics so am baffled as to what it may be. I've just bought some new plugs and am hoping this may be the
cause.
Any ideas? Is there anything else I should check?
Thanks in advance
Iain
Bike engines do tend to be sensitive to battery voltage. My last engine would sound perfect when turning over, but if the battery voltage had dropped,
the ECU would not allow the spark to fire. Try a charge of the battery as your first solution.
I would be surprised if it was the spark plugs - if it worked 3 weeks ago, then at the worst case it might run rough if the plugs were a bit pants - I
would not expect it to not run at all.
Got to the bottom of this in the end.
Turns out what I think is the cable that runs to the crank sensor was disconnected, DOH! Plugged it back in and hey presto its runs.
Seems to idle smoother than before (might just be in my head) thanks to the un-necessary spark plug change!
Iain
