Author: Subject: transit trackrod ends???
punker
posted on 12/4/05 at 03:42 PM Reply With Quote
anyone know which transit the trackrod ends for the tiger avon front upper wishbones is from?
flak monkey
posted on 12/4/05 at 04:00 PM Reply With Quote
I assume they are the same as any other locost....
EDIT; ooops wrong number...
Correct quinton hazel # for the drag link is:
QD1117RHT
[Edited on 14/4/05 by flak monkey]
Sera
http://www.motosera.com
Peter Cowley
posted on 12/4/05 at 04:12 PM Reply With Quote
try ....dare i say it.... lolocost dirt cheap when I bought some off them for my westy.
flak monkey
posted on 12/4/05 at 04:20 PM Reply With Quote
Problem with lolocost is the parts are cheap, but the postage is steep (£6 for postage!) They should only be about £5 each from your local motor factors (I got a pair of Escort TRE's for £9.90 from Wilcos!).
Always worth saving on postage...
Sera
carlgeldard
posted on 12/4/05 at 04:35 PM Reply With Quote
There are two tranny track rod ends M18 and M20 I think the M18 is the more common one. I think Northy told me his are the M20 ones from Tiger. Mine are M18 but I made the wishbone myself.
Carl
punker
posted on 13/4/05 at 08:22 AM Reply With Quote
i'm building my own wishbones as well but have already had the turned part made to acept the book "transit ball joint" , i went into my local wilco but they said there about 4 different transit trackrod ends? i know they are m20x1.5 but which transit are they from?? also when you made your wishbones did you make the jig from metal or wood and how did you cut your tubes to fit other tubes??
flak monkey
posted on 13/4/05 at 08:39 AM Reply With Quote
The book transit rod ends are M18x1.5 not M20.
The AP Lockheed number is TA298 (according to the book)
[Edited on 13/4/05 by flak monkey]
Sera
punker
posted on 13/4/05 at 08:54 AM Reply With Quote
yeh the champion book does but the avon book says m20x1.5 and says "the top wishbone ball joint is from the ford transit", just wanted to know which transit?? thanks
carlgeldard
posted on 13/4/05 at 09:12 AM Reply With Quote
I got the threaded tube from lolocost (I think) they cost about 4 quid then got the track rod ends from a local motorfactors. They fitted so I must have been lucky.
The jigs that I made were made from 18mm plywood and Aluminium angle/flat bars all screwed together.
Carl
Viper
posted on 13/4/05 at 05:20 PM Reply With Quote
The M20 joints are mk2 transit track rod ends
The M18 are transit drag link ends , either will fit the taper on the cortina upright.
I made steel jigs.
do a search on here for a little program called tube mitre this will show you how to properly "fish mouth" the ends of your round tubes
