ddt
posted on 16/4/06 at 09:11 AM |
Avon -> locost book??
Hello,
I order one Avon.I want to build the most things on my own.
Does any one have drawings ?? Fit wishbons like the locost book (Champion??)
Thanks any help welkom
Aboardman
| posted on 16/4/06 at 11:38 AM |
are the drawings not in the avon book?
beware as there are mistakes.
t.j.
| posted on 17/4/06 at 10:16 AM |
There are drawings in the "orange" book but the are incorrect. The best is re-draw the whole thing.
I'm building my own, but as the time grows the more it becomes a new locost.
smaller front, Wider at driverseat, longer, different rear, wider track.
The big mistake i've found:
90 degr. at bottom at front must be at top, or you will have zero degr castor.
you will be missing some measurements. But if you re-draw you get your own measurements. Critical is bumpsteer, At the rear i've replaced the
inner brackets lower to respect the static "roll-centre"-principal.
I'm not using tiger grp. Make my own bodywork of alu like locost. The bonnet and nose of a donkervoort.
There are a lot of pictures around here. So with the book and this forum it must be possible.
