Big Daz
| posted on 13/9/06 at 08:42 AM |
1st of MANY questions I am sure.
Ok, following on from our "Another newbie" thread,
1st inspection of out new project reveals that the front wheels have +ve camber instead of -ve, even when the top ball joints are screwed in to the
minimum with no lock nuts.
I would guess that its got sierra hubs rather than the preferred cortina ones.
What are required modifications to get the correct camber?
Can I slot the bottom wishbone holes to allow the base of the wheel to swing out more?
Daz
ayoungman
| posted on 13/9/06 at 08:56 AM |
This can happen on Avons. Check the top wishbone dimensions carefully. Sometimes they do not allow the top ball joint to be screwed in enough. I
definately would NOT slot any hole anywhere in the suspension system. HTH
"just like that !"
soggy 3
| posted on 14/9/06 at 02:06 AM |
I spotted that he put sierra hubs on before as when i brought my part finished avon i had the same problem the easy fix is get cortina ones they can
still be found at some scrappies.
Lightning
| posted on 15/9/06 at 09:16 PM |
Better still make 75mm wider ones. The handling will improve. The track will be the same as the rear.
