punker
| posted on 27/5/03 at 11:55 AM |
windscreen question
i know i'm not at the windscreen point yet but just doing a bit of forward planning;
i'm thinking of not having a windscreen and having a small aero screen (like the zr100) cuz you dont need wipers and demist, what i want to know
is how bad is it driving with no windscreen, does the aeroscreen provide enough deflection of air not to need a helmet?
also were do you stand if you get your car SVA'ed without a windscreen (with aeroscreen) and then change ya mind do you have to SVA it again??
if not surely it would be easier to get past the SVA that way????
David Jenkins
| posted on 27/5/03 at 12:06 PM |
Driving without a screen has good points & bad points
Good:
You don't get the bad turbulence that you get from a flat screen (without sidescreens). Instead you get a smooth flow of air past your head.
You don't have to worry about wipers & washers.
Bad:
You will certainly need eye protection. You should also consider ear protection, even if it's just expanding plugs. Depending on the size of
the aeroscreen, you may want face protection - insects can hurt quite a bit, stones thrown up by cars can hurt a lot!
I'll be using a helmet, but that's mainly because I'm not fitting an aeroscreen initially. I'll review the situation once I
get the screens.
P.S. You don't have to go back for another SVA if you subsequently fit a windscreen (but I wouldn't be too surprised if they cover that
loophole at a later date).
Mark H
| posted on 27/5/03 at 12:58 PM |
Punker,
To answer one of your questions exactly (all the rest David has answered, and is all true!):
No they do not seem to deflect enough air. Mine is just a flat perspex screen, but the air hits me halfway up my helmet (the one on my head!). I
can't see, hear or breathe without it.
I would get the SVA without a full screen, then see how it goes.
My 2p.
Mark
Mark Harrison and
Q986 KCP back from the dead...
punker
| posted on 27/5/03 at 01:35 PM |
thanks..i'll go for the aeroscreen to start with and use a helmet (the one on my head) if necessary.
gjn200
| posted on 27/5/03 at 04:17 PM |
When i had my test drive in the avon, I could hardly breath with the full screen at 70 ish, so I am going no screen and helmet (maybe I should say
test passenger" )
[Edited on 27/5/03 by gjn200]
<- Me!
