les
| posted on 18/12/06 at 09:26 PM |
help!
chaps,
I think I may have a problem,
just ordered some wheels for the avon
195/45/15 offset 38, ford 4 stud fitment
a user on the tiger forum has different 15" wheels,
can anyone tell me if they will be ok for the avon?
heres hoping!!!
les
soggy 3
| posted on 18/12/06 at 09:56 PM |
Hi les like you i also have Et38 offset i am running 195/50/15 it does look a bit as if the wheels might rub under hard cornering but as i havent
driven mine i cant say but i think it will be ok after reading this thread.
http://www.locostbuilders.co.uk/viewthread.php?tid=44588
Marcus
| posted on 19/12/06 at 09:11 AM |
If the Avon uses Sierra uprights, ET38 are the ones you need, if they're Cortina, ET15ish is where it's at.
Marcus
Because kits are for girls!!
les
| posted on 19/12/06 at 09:28 AM |
Hi,
Thanks guys, I have an avon with cortina front uprights, and sierra rear axles/ diff / brakes.
Its typical!! I have the wheels on order and could have ordered any offset / size tiger advised the 38 offset!!
Soggy, where does it look like it might rub?
les
soggy 3
| posted on 19/12/06 at 11:17 AM |
Its on the outer edge of the arch but like i said without having a finished car i dony know how much the suspension compresses under hard cornering.
les
| posted on 19/12/06 at 08:08 PM |
that doesnt sound too bad,
hopefully Ill be ok, handling wise, I guess you want them out there at the outer edges of the bodywork,
do the fronts look ok so far?
les
t.j.
| posted on 19/12/06 at 09:45 PM |
quote: Originally posted by les
Hi,
les
fill it up to ET 15 at the front. 38-15=23 mm space.
soggy 3
| posted on 19/12/06 at 10:03 PM |
The fronts are fine i will take some pics tomorrow of the front and the back.
