Author: Subject: Sierra Diff
AvonBelgium
posted on 22/8/03 at 10:22 AM Reply With Quote
Sierra Diff
Hi,
Yesterday evening I was mouting my sierra diff in the Avon chassis, and I was a little disapointed to see that the left upper mounting brackect was not in the right place. It had to be more to the left !!
Can it be that this is due to the fact that I have one of those rare 7.5" diff ( out of a 2.0 i dohc from 1989) ??
All the other mounting point are OK, also the upper right one !!?? The only other thing I have to, besides replacing the left upper bracket, is to gring a little bit from the casing from the diff, to get clearence in the tunnel.
Can someone tell the differance between the 7" and 7.5" diff
AvonBelgium
carlgeldard
posted on 22/8/03 at 09:19 PM Reply With Quote
Hi
I think you will find that it is the chassis is at fault if it is a tiger built chassis. You will also find the round tube that supports the steering column bush is out of line with the upper support brackets. This is something to do with the lack of quality control at tiger sorry for the bad news.
[Edited on 23/8/03 by carlgeldard]
Lightning
posted on 2/9/03 at 12:07 PM Reply With Quote
No, its a different size diff. Don't fret.
I ground off the bracket and welded 50x50x5 angle cleat on. This means that you have plenty off meat to weld as the angle will attach to the chassis uprights.
I have rolling chassis now and no problems.......yet....famous last words
AvonBelgium
posted on 2/9/03 at 10:35 PM Reply With Quote
Steve,
Thanks,
I just did this this evening and it seems to be OK, like you discribed.
Are there other problems that you had or points of extra attention, I would appriciate some advice.
Like for the front suspension it seems to be almost inpossible to get the camber at 0 or negative.
Stu16v
posted on 3/9/03 at 09:18 PM Reply With Quote
Just a thought....
Are you trying to set up the suspension without the engine in, or with the suspension unloaded? If the car isnt at the 'desired' ride height, then chances are it will be impossible.....
HTH Stu.
gjn200
posted on 4/9/03 at 04:00 PM Reply With Quote
Have you tried cutting the top ball joint lock nut in half?
<- Me!
AvonBelgium
posted on 7/9/03 at 11:12 AM Reply With Quote
Many Thanks,
I first install the engine and see with wath I end up, and try then the proposed solutions.
Will keep you informed
ayoungman
posted on 15/9/04 at 03:34 PM Reply With Quote
diff not fitting
I had the same problem, thought it was the chassis that was wrong but it wasn't. The sierra ESTATE diff is a little wider in the casting so won't fit. Take it to a scrappy and swop it over for a 'normal' one.
"just like that !"
tractorboy
posted on 16/9/04 at 07:34 PM Reply With Quote
slightly off topic but the rear brakes are also bigger on the sierra estate.it doesnt make a difference but just something to be aware of.
