DaveFJ
| posted on 17/7/07 at 12:09 PM |
Avon wiring - fuel pumps
I am trying to work out how best to wire in my fuel pumps to my Avon Loom...
Thing is I'm not the best at vehicle electrics so need a little guidance
here is the problem:
I have the standard Tiger 6 fuse loom which presents 2 wires (+&-) to the rear of the vehicle. To my knowledge this is not coming from a relay as
there are only 2 relays on the loom - 1 for flashers and the other, I think, is lights...
Not sure on how thick these wires are and therefore thier capacity...
I have a Sierra standard EFi pump and a Facet red top pump acting as an LP pump to fill the swirl pot.
I also need to wire in a safety cut out 'bump' switch and the fuel pump output from the Megasquirt. (I think I also have an output from my
alarm - but I need to confirm this....)
So... my question is this.. what is my best way of going about this? should i run a decent wire to the rear end and use the current wire to work a
relay? or will the wire in the loom be up to the job of running both pumps(if you know your way round the Tiger loom)? If so should I run a wire from
my MS to the relay via the cut off switch? And if my Alarm does have a fuel pump supply do I need to use a second relay?
Whilst i am on the subject, I was wondering where best to mount the relay? I had a feeling that it was probably not good to have it next to the pumps
etc?
Clear as mud?
I know this may be better in the Electrical section but I wanted to get some info from the Tiger community....
Dave
PeterW
| posted on 17/7/07 at 01:07 PM |
Dave
From what I have seen of the Tiger loom, its up to running about 12a through the wiring to the back of the vehicle.
The wire in question runs directly from the 2nd (?) fuse, straight through to the plug at the back. They are pretty easy to trace, and you could chop
the loom to drive relays etc. Its not a complex loom, just about 3ft too long
Pete
DaveFJ
| posted on 17/7/07 at 02:09 PM |
B*gger is, loom is now all nicely routed buttoned down and wrapped in convoluted tubing
It's gonna be a right bitch to get at under the dash
All my fault - I didn't think this through earlier
Any idea what sort of current I will be looking at for both these pumps?
Dave
DaveFJ
| posted on 18/7/07 at 09:45 AM |
Measured the O/D of the wire in the loom last night. (I know it doesn't mean a lot because i reallyu need to measure the core but - hey
it's all I have for the mo....)
anyway the wire is reasonably meaty @ 1/10" or 2.5mm
so do people reckon this might be up to the job of running both pumps?
thing is this wire is already in the loom and controlled by the ignition so would be good if it could be used and then just run a cable from the
megasquirt via the bump switch to a relay so that the MS and/or bump switch can shut off the pumps as neccessary
Rudy
| posted on 18/7/07 at 09:56 AM |
Yes I think you can do in that manner. And 2.5mm is ok
Sorry about my English
