Author: Subject: wheel alignment gunson trakrite
jamrogers
posted on 23/9/08 at 08:36 PM Reply With Quote
Has anyone used a gunson trakrite for wheel alignment? u drive over it and as the platform is on a roller bearing, the table rotates showing the angle of alignment?
good idea or useless bit of kit?
[Edited on 23/9/08 by jamrogers]
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
JohnN
posted on 23/9/08 at 08:57 PM Reply With Quote
I believe that for a production car, the basic ones that have fixed camber & castor by virtue of the suspension geometry, then the trackrite will help with indicating toe in/out errors and the change in toe needed.
However, for a seven, without knowing that camber & castor are correct (or even what they should be) then it's going to be much less useful.
I have one, and it has helped, but I STILL have no idea what my camber & castor measurements are or even what they should be.
One of these days I'm going to get it setup at a laser wheel alignment place to get some sort of basis to work from.
posted on 23/9/08 at 09:21 PM Reply With Quote
Best thing for camber adjustment is a cheapo inclinometer off Ebay. The nice ones have magnets on the best so you can attach it to the brake disc. Voila! Job done. Easy camber measurement.
For measuring toe-in the best thing (IMHO) is a decididly locost pair of tracking calipers.
At some point I really must do a tutorial on tracking using these things. I did it the other day and it's a PoP!!!
UncleFista
posted on 24/9/08 at 01:46 AM Reply With Quote
They work fine, I've set up the Locost and a couple of tin-tops, several months later tyre wear is even with no handling problems. It paid for itself in no time.
Tony Bond / UncleFista
loggyboy
posted on 24/9/08 at 09:55 AM Reply With Quote
im in the process of making my own tracking bar. It will look a little like this:
with an adjustable threaded rod to measure the distance between front a rear most points on the front wheels.
It could also double as a camber measurer with some tweeks.
So far parts have cost under £40.
Mistral Motorsport
jamrogers
posted on 27/9/08 at 02:37 PM Reply With Quote
i thought about making something like that but the bar would have to be quite thick to make sure it doesn't flex...
YouTube
