Author: Subject: Rear Wheel Size
obr_technology
posted on 27/12/13 at 03:31 PM Reply With Quote
Rear Wheel Size
Seasons Greetings!
I'm hoping somebody can offer some advice on rear wheel size for an Avon.
I've got independent rear end with drum brakes and am hoping to fit some 8 x 13 Compomotive Cxr's, which an offset of 20 that are currently for sale.
I'm away for Xmas so unable to measure the car but having looked back on this forum people seem to suggest that standard sierra rear wheels need a minimum of ET35 as otherwise they hit the uprights. As I'm assuming these sierra wheels would be around 5" diameter, the online calculator which I've used before suggests that 8" rims would protrude 20mm more into the centre of the car and therefore clash with the uprights.
I hope this makes sense, and just wanted to make sure I'm not wildly out with my calculations as the wheels would be ideal for what I want.
Has anyone else on here used wide 13" rear wheels on an Avon? I can't go any larger in diameter but need them to be wide.
Smoking Frog
posted on 27/12/13 at 03:56 PM Reply With Quote
Have a play with this as I don't think they will protrude 20mm more into the centre. Admittedly it depends on the original wheel size.
http://www.willtheyfit.com/
[Edited on 27/12/13 by Smoking Frog]
obr_technology
posted on 27/12/13 at 04:46 PM Reply With Quote
Thank you smoking frog, that is an excellent tool and far better than the one I was using.
melly-g
posted on 28/12/13 at 02:13 PM Reply With Quote
if your using Tigers uprights you wont get 13's to fit. I think the very smallest wheel would be 14" at a push as well!!
laptoprob
posted on 28/12/13 at 04:57 PM Reply With Quote
Melly is right to a degree. You can get 13's on there but have to mod quite a bit and also use calipers not drums.
You are best to stay with ET35 as they wont foul at all under any type of driving.
I have 195/50/15 ET35's and they never bother me as i also have ET30's with slicks for track and these catch the rear arches under heavy cornering(even lip ground off on the inside of the arch).
In a nutshell ET20 are no good, sorry
[Edited on 28/12/13 by laptoprob]
http://www.youtube.com/watch?v=ajlF4nWJtGA
