Author: Subject: Avon prop shaft
shades
posted on 31/7/05 at 06:40 PM Reply With Quote
Avon prop shaft
Had a trial fit of my Diff, prop shaft and gearbox.
With the gearbox pushed back as far as possible. How much length should I have left where the prop shaft goes into the gearbox? I guess there will be some free play?
Andrew Bause
posted on 31/7/05 at 09:41 PM Reply With Quote
Should be roughly 25 - 35mm of the shaft visable past the rear gearbox oil seal, from memory?
Cheers!
Andy Bause
Road Legal VX 16V AVON
We have been doing so much with so little for so long - Now we can do anything with nothing!
shades
posted on 1/8/05 at 06:57 AM Reply With Quote
Thats good... It about that on mine. Was thinking it would be about 5mm
DarrenW
posted on 1/8/05 at 09:05 AM Reply With Quote
The standard way to spec a prop is to measure end of gearbox to the diff flange and also specify that an inch behind the nose is required. This means that 25mm of the shaft that goes into the gearbox (nose) is showing. Yours sounds spot on right.
