edspurrier
| posted on 29/3/07 at 08:28 PM |
Avon Gearbox Mount
I bought my Avon kit part built (by Tiger London). It came with a trackday only unstamped engine so I've got to the stage of taking that out to
put a new one in - and found the gearbox mounts haven't been bolted to the chassis. They're just sitting on top of a couple of chassis
bars with no bolt holes drilled.
Is this how it's meant to be? Seems a bit wobbly to me - and it's going to be Very Interesting drilling two bolt holes with the aluminium
panel above rivetted on!
shades
| posted on 29/3/07 at 09:51 PM |
I have bolted mine to the two extra box sections in the tunnel. Mine is the sierra one.
You have mentioned mounts in the plural, so I guess you have more than one?Guess you may have a different setup?
If you cant get to the mount/s from above it should be possible to get to them from below and drill up?
Adrian
edspurrier
| posted on 29/3/07 at 10:14 PM |
Thanks. I've got one mount with bolt flanges either side, each sitting on a little box section.
I think I'll have to drill up from below, or get one of those 90 degree drill adaptor things. Either way it's going to be a nightmare to
drill in the right place without going through the fuel pipe.
Something they really should have done properly.
