gokou
| posted on 27/5/07 at 03:44 PM |
Zetec SE in a Tiger Cat E1?
I'm new to this forum, looks like you have a interesting mix of members here with some interesting cars.
I'm currelty building a Tiger Cat E1 and was thinking about fitting a 1.6 ZETEC SE (Sigma) engine to a Type 9 gearbox.
Does the Zetec SE require a shortened sump to fit in the Tiger, the old Pinto I had needed one.
Ultimately I want to fit bike throttle bodies onto the Zetec SE, with a megasquirt ECU.
There seems to be very information around at the moment with regards to
Zetec SE's being used in 7 style cars.
Any information would be greatly appreciated.
Thanks Che.
takumi
| posted on 27/5/07 at 04:01 PM |
Hi gokou,
The Zetec-SE is a fab little engine. I am currently fitting one into my lcoost chassis to a type9.
The engine is not very tall, and to save ground clearance you can mount the engine slightly higher than you would normally .
I've mounted mine with about 50mm bonnet clearance, that leaves the sump poking down about the same.. If you mount the engine very close to
the bonnet, the sump will have plenty of ground clearance..
Mine has bike throttle bodies (bing) and a MS ecu, but I haven't run it yet, will do as soon as the gearbox is also mounted and exhaust
finished..
If you want some more info on theZetec-SE in rwd, www.shawspeed.com sell lots of tuning packages, and a rwd kit which
includes a alloy bellhousing for a type9.
tak
[Edited on 27-5-07 by takumi]
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
ned
| posted on 27/5/07 at 04:12 PM |
westfield and quantum also do bits for the se, worth a ring round to compare prices
beware, I've got yellow skin
Werner Van Loock
| posted on 27/5/07 at 08:26 PM |
as does griffin who advertise on here
http://www.clubstylus.be
gokou
| posted on 28/5/07 at 02:12 PM |
Thanks, I'll check out the companies mentioned.
