Lightning
posted on 23/2/05 at 08:57 PM |
Sunday should be Ok
andrew.carwithen
posted on 23/2/05 at 09:07 PM |
Steve,
would Sunday afternoon be o.k - say about 1.30 -2.00ish? (SWMBO's doing a car boot in the morning and so I'll be entertaining the
kids.)
Andy.
Lightning
posted on 23/2/05 at 09:09 PM |
Yes thats OK. BTW have you got Rob Dukes Tel No.? U2U me
andrew.carwithen
posted on 23/2/05 at 09:31 PM |
Sorry Steve,
I thought I had it in an old email - must've deleted it.
But he does sign on this forum as 'robbydee' if you want to U2U him.
See you Sunday....
Andy.
Lightning
posted on 23/2/05 at 09:34 PM |
No worries just left a post on SWTOC. Like the sound of a sprint do in Cornwall
[Edited on 23/2/05 by Lightning]
andrew.carwithen
posted on 23/2/05 at 09:56 PM |
Yep, sounds great, I tried to find some info earlier on Portreath 'Run what yer brung' with very little success. Only snippet I found
states that spectators and photography isn't allowed! which is a bit of a bummer! May ask for more info on 'events' section.
BTW, did you renew your rear hub bearings? If so, where did you get them from? and did they come with the oil seals?
Did you have to remove the ABS teeth when you fitted the driveshafts?
I've got one of the hubs bubbling merrily away in the electrolysis bath at the mo' so will try to source new bearings tomorrow.
Andy.
Lightning
posted on 23/2/05 at 10:13 PM |
no
no
and don't know where
helpful arnt I
Northy
posted on 26/2/05 at 07:11 PM |
I've been looking at the bits and doing a fair bit of thinking....
I'm just coming up with a cunning plan that will be much less work than fabbing new uprights, but more work than just bolting them on.
I'll look into if its possible tomorrow and hopefully post pictures.
Graham
Lightning
posted on 26/2/05 at 08:12 PM |
Can't wait Baldrick
Northy
posted on 26/2/05 at 09:22 PM |
Graham
andrew.carwithen
posted on 26/2/05 at 10:31 PM |
So Graham,
Have you got rid of the ABS teeth yet?
I've tried to undo the six torx bolts to remove the joint and splined shaft assy from the driveshaft itself but they're stuck fast!
(I've sheared one torx bit trying, already.)
Was wondering if they're a lefthand thread like the L/H retaining nut?
Apart from that, I've had great results de-rusting the hub carriers and drive flanges in the electrolysis bath! It works brilliantly!
Regards,
Andy.
decay
posted on 7/3/05 at 04:05 PM |
New rear uprights created:
decay
posted on 7/3/05 at 04:18 PM |
Tigers own compared
andrew.carwithen
posted on 14/3/05 at 08:26 PM |
quote: Originally posted by decay
Hi
I,ve come to the same problem and found a few sticking points when using the stock avon rear drum upright with disk hubs.
1) The 4 holes of the hub do not line up with the tapped holes in the upright
This has aparently been solved by welding up, redrilling and tapping according to tiger. Just how you are going to drill and tap a hole 15mm? deep is
beyond my ability. You are going to need a neat flat bottom drill bit.
Whilst your at this make sure the holes are dead square around the centre hole or the drive shaft will hit. In its current state it aint pretty.
2) The Lobro shaft end is to dam big to fit in the hole. You could lathe it down taking off the ABS teeth so the sides are parallel. POINT A on
3) The Lobro shaft end is to dam short to fit, when the baring is tightened up it pulls the shaft end in to meet the inside edge of the upright,
You would have to lathe some metal off POINT B off the shaft and take back the lip of metal on the inside of the upright.
After much thought I'm going to ebay my uprightd and build completly new ones base on the Luego design of a flat plate that everything is either
welded of bolted to, a vast improvement.
What a pain in the ar.e this disc and LSD conversion is turning out to be!
Firstly, I had the dia. of the stub shaft turned down (inc. ABS teeth) to 75mm along its length so that it passes through the rear uprights no prob.
(Local engineering firm charged a mere £10 to do both sides.) Yes, the ABS teeth are hardened but a carbide tipped tool soon made easy work of
them!
Sure enough, the holes in the disc type bearing carrier did not line up with the holes in the upright but, again, use of a round file to elongate the
holes soon fixed that little problem. Although my calipers are going to have to be mounted on the front of side of the hub as opposed to the rear
(like Lightning's)
But the main problem is that when tightening the hub nut, the whole of the stub shaft is pulled through the inboard side of the upright and the lobro
flange is then fouling the upright. This means that the hub nut cannot fully tighten onto the wheel bearings and so there is about 5mm plus play in
the bearings (same as 'Decay' is experiencing in point 3 of his above thread).
Iwas wondering if the lobro stub shafts on non-ABS disc models are a different design? (Lightning, where are you? I believe you fitted non-ABS type
drive shafts)
Andy.
Northy
posted on 15/3/05 at 07:57 AM |
Andy,
Lightning swopped the uprights from side to side to put the caliper at the rear.
Still not done mine
Graham
Avoneer
posted on 15/3/05 at 12:10 PM |
Told you all - new tube in the upright. An afternoons work and hardly any expense. Job done.
Pat...
Northy
posted on 15/3/05 at 06:11 PM |
Pat,
How do you suggestyou do that then Easily?
Don't you think it would be easier to make new ones?
Graham
decay
posted on 16/3/05 at 09:57 AM |
Check out the photos, of before and after.
me thinks you need a very well equiped workshop to be able to do that (twice) in an afternoon.
Avoneer
posted on 16/3/05 at 12:34 PM |
Maybe a long afternoon then.
carlgeldard
posted on 16/3/05 at 01:22 PM |
Uprights
Hey that my upright on the right.Stripped the suspension made the jig and did the mods in about 3 hrs. It takes longer for the paint to dry.
Come on Graham get you finger out. I will have passed my SVA at this rate.
Carl
PS Thats both in 3 hrs
[Edited on 16/3/05 by carlgeldard]
Northy
posted on 16/3/05 at 06:27 PM |
But Carl, aren't you a welder? And didn't you make them from scratch?
As I said, probably easier to make them from scratch, rather than modify existing ones
Graham
carlgeldard
posted on 16/3/05 at 06:53 PM |
Welder
Yes I was a welder in a passed life. The uprights were bought from Tiger thats why I have modified them just like everthing from Tiger.
Things from Tiger that I got
Book & Dimensions (Crap)
Uprights (Also Crap)
Bodywork (words fails)
Steering rack (fine but did'nt fit chassis as the book was wrong)
Graham do you want me to modify your uprights for you.
Carl
andrew.carwithen
posted on 16/3/05 at 07:44 PM |
Carl
Carl,
As you've made up jigs, does that mean you'll be offering an Avon upright modification service to the rest of us? (for a price, of
course!)
Andy.
Northy
posted on 16/3/05 at 07:55 PM |
Music to my ears!
How did you do it Carl? I don't think I'd trust my welding to suspension parts
Did you alter the mounting plate also to put the holes in the right place?
[Edited on 16/3/05 by Northy]
Graham
carlgeldard
posted on 16/3/05 at 10:05 PM |
upright service
Why don't I do Graham's uprights and he can take photos and write a description. Then post the results on here for you to do yourself. A
small price to pay don't you think Graham.
Carl
