GO
posted on 19/1/04 at 01:18 PM |
MOTs...
Apologies in advance for the slightly more mundane post that the current vein of the threads in here at the mo!
Anyone know what the MOT rule is re the handbrake?
On my main car, the handbrake cable has stretched on offside leading to little or no effect on that side. However, it still holds the car quite
happily on a significant slope.
The long and short of it is that road tax is about to expire, and I don't have time to fix the problem before the only mot slot I could get. So,
need to decide whether I should SORN it now just to make sure I dont get stung!!
Cheers guys.
posted on 19/1/04 at 01:20 PM |
Most MOT stations will test the handbrake on rollers, so they'll know immediately if one side is sick.
DJ
GO
posted on 19/1/04 at 01:30 PM |
bummer.
do you know what values they use to compare against?
ChrisW
posted on 19/1/04 at 02:40 PM |
I'm sure I read the handbrake had to pull 0.25G deceleration to pass MOT. Might have made that up tho
Chris
My gaff my rules
GO
posted on 19/1/04 at 02:44 PM |
Thanks guys,
I guess I'll SORN it, and chance the MOT, may get through, you never know. At least I'm not risking an uneccesary £80!
andyps
posted on 19/1/04 at 11:28 PM |
The total retardation effort is related to the weight of the car to determine whether the handbrake passes I think - but it has to be effective on
both wheels.
My MOT guy had to get out his calculator to see if he could pass our mini on it's handbrake once it was that ineffective - had it been any
heavier it would have failed.
posted on 20/1/04 at 10:13 AM |
I'm sure the effort has to be equal to both sides for the test. It has to be something like 13% of the total braking effort.
yours, Pete.
posted on 20/1/04 at 10:54 AM |
Generally the MOT test isn't like the SVA braking test - all they do is put the back wheels on a driven roller and heave on the handbrake lever.
The tester watches a pair of dials, and if the needle goes past a given reading on both sides then it's a pass.
DARRYL
posted on 20/1/04 at 07:22 PM |
I n dual brake system, it has to achieve 16% performance. It must have a pretty crap handbrake, not to make this!
