Author: Subject: attaching ally panels
Miks15
posted on 14/12/09 at 10:52 AM Reply With Quote
Im going to be attaching my interior ally panels soon (tunnel and rear bulk head) and i just would like to know what spacing you have used on your rivets? and also what size rivets you have all used?
For the top tunnel panel im going to attach it with rivnuts so i can remove it when iwant to What size rivnuts would you use? And what is the best way to seal it?
Mikkel
mr henderson
posted on 14/12/09 at 12:14 PM Reply With Quote
Something like 75-100mm will be fine. Use the CBS trick of marking a piece of elastic at regular intervals, then stretching it over the first and last hole in a straight line to automatically get the in between ones equally spaced.
You will want to make sure adjacent panels have the same spacing.
I use 4mm rivets (Screwfix is a good place to buy them)
If it was my car I would use rivets instead of rivnuts, how often are you going to be removing the panel? Quick and cheap to drill them out and put new ones in aterwards. On a customer's car I would do what they wanted, of course.
If you do use riivneus you will need to use the countersunk type.
Rubber strip is good for sealing removable panels, CBS do 1.5mm sheet.
Mr Whippy
posted on 14/12/09 at 12:24 PM Reply With Quote
that's a clever idea, wish I’d thought of it
eddie99
posted on 14/12/09 at 12:26 PM Reply With Quote
I think i rivetted my panels every 75mm. I was told to use 4mm Monel rivets, bit more expensive but suppose to be better in terms of rusting....
eddie99
posted on 14/12/09 at 12:27 PM Reply With Quote
In terms of sealing, i used Duralec Jointing Compound and Masterseal. One to dip the rivets in, and one to seal it down to the chassis.
Hope that Helps
Eddie
MikeR
posted on 14/12/09 at 01:07 PM Reply With Quote
Are the screwfix open or close ended?
I thought they where all open ended which means small holes for moisture to get in or am i miss-understanding?
matt_gsxr
posted on 14/12/09 at 01:10 PM Reply With Quote
These guys are good
http://www.prifast.co.uk/
4mm gas tight rivets. Much nicer quality than screwfix/B&Q/Homebase, and probably no more expensive.
I spaced mine at 50mm spacing and sikaflexed.
Get more than you think you need!
Matt
tomgregory2000
posted on 14/12/09 at 01:57 PM Reply With Quote
I have to dissagree with this, the trans tunnel cover has been on and off so many times i would hate to drill out and re rivet each time.
Mine is held on with velcro and is fantastic!!
ReMan
posted on 14/12/09 at 03:30 PM Reply With Quote
Me too
speedyxjs
posted on 14/12/09 at 05:00 PM Reply With Quote
X2
mr henderson
posted on 14/12/09 at 05:03 PM Reply With Quote
X2
If it works for you then that's good. Does sound as if the panels were fitted a little bit early in the build?
tomgregory2000
posted on 14/12/09 at 05:53 PM Reply With Quote
It was just the trans tunnel top that is held with velcro, no other pannels
posted on 14/12/09 at 06:20 PM Reply With Quote
If you use some kind of sealing strip then you can get away with standard rivnuts, you just need to cut out larger holes in the sealing strip.
mr henderson
posted on 14/12/09 at 06:46 PM Reply With Quote
Though you would need thicker rubber strip to get a good seal
posted on 14/12/09 at 07:53 PM Reply With Quote
Better than elastic try a chalk line!
mr henderson
posted on 14/12/09 at 08:42 PM Reply With Quote
Don't think you've quite got the point, Rusty, unles your chalk line is very stretchy and can be marked off at intevals
[Edited on 14/12/09 by mr henderson]
Fozzie
posted on 14/12/09 at 09:58 PM Reply With Quote
Didn't use any rivets.....
Fozzie
MikeR
posted on 14/12/09 at 10:39 PM Reply With Quote
^^^^ you're my inspiration!
boggle
posted on 14/12/09 at 11:06 PM Reply With Quote
have just drilled and tapped my box section m5....
u2u me for details
RK
posted on 15/12/09 at 12:41 AM Reply With Quote
I used velcro on my rearward tunnel panels, except the top, which just sits there.
[Edited on 15/12/09 by RK]
SPYDER
posted on 15/12/09 at 11:46 AM Reply With Quote
On our Locost we painted all our panels prior to final fitting.
75 or 80mm spacing for the rivets. As previously stated, try to match up the spacing on adjacent panels if aesthetics are your bag.
Geoff
[img][/img]
