RedAvon
| posted on 28/5/10 at 11:19 AM |
alternator bracket
clearance issue for LRA101 alternator hitting chassis - has anyone got an engineering drawing or a sketch with dimensions to make a replacement
bracket for the cast Sierra one on a 205 block please? I've seen some pics on the forums using 5mm plate and welded tube but measuring it all
with the engine in place is a pain.
jabbahutt
| posted on 28/5/10 at 11:23 AM |
you have a U2U
RichardK
| posted on 28/5/10 at 11:52 AM |
I can measure mine over the weekend if you draw a blank
Rich
Gallery updated 11/01/2011
RedAvon
| posted on 28/5/10 at 03:35 PM |
thanks guys - the drawing and picture will see me right - now for a bit of metalwork at the weekend!
DaveFJ
| posted on 1/6/10 at 08:11 AM |
dont forget you can cut down the block mounting lugs quite a bit, that give you a lot more room to play with
Dave
