Lime zest
| posted on 4/7/10 at 08:39 AM |
Avon zetec exhaust manifold
Hi guys, i am having trouble with my exhaust manifold. First tiger manifold would not fit my zetec so i sent it back to be re-welded. Got the exhaust
manifold back but still not a good fit and the welds are not perfect....Has anyone else had this problem? Does the westfield manifold fit? Any
suggestions on where i can buy a better manifold?
scutter
| posted on 4/7/10 at 09:32 AM |
Where are you fella? Some one maybe local to help weld it up for you in place.
ATB Dan.
Strontium Dog
| posted on 4/7/10 at 09:50 AM |
In what way does it not fit? Would a little heat and a tweak fix it or does it need to be cut and shut? Like Scutter said, where are you? I'd be
happy to help if you are near me and my oxy/propane and Tig are portable with my trailer!
I'm on Dartmoor!
[Edited on 4/7/10 by Strontium Dog]
Lime zest
| posted on 4/7/10 at 10:57 AM |
exhaust
Thanks guys, i am in bridgwater somerset. i will try and post some pictures latter to show the problem.
big_wasa
| posted on 4/7/10 at 11:13 AM |
I agree quality is poor but it did polish up ok and fitted ok. In what way does it not fit ?
Lime zest
| posted on 4/7/10 at 11:25 AM |
Exhaust problems
  Exhaust 2
  Exhaust 1
Hope this shows the alignment problems...
Just will not fit to the head!! Either i can fit the pipes into the collector and have the shown results, or fit to the head and not be able to fit
the collector....
deltron63
| posted on 4/7/10 at 12:25 PM |
That's rubbish. Sent it back and get one from another supplier
scutter
| posted on 4/7/10 at 12:56 PM |
I'd send that back, not fit for purpose and all that.
Dan.
snakebelly
| posted on 4/7/10 at 02:13 PM |
send it back and demand a full refund including P&P, its obviously rubbish and looks to me like it belongs in the bin!
big_wasa
| posted on 4/7/10 at 02:46 PM |
From what I remember.
You loosley bolt the primarys to the head then try and work the collector on.
Then tighten up
The collector is a seperate item ?
I also seam to remember that I couldnt get it to fit my putting it to gether then offering it up to the head.
Long since sold it and bought one from Fisher sports cars.
Lime zest
| posted on 4/7/10 at 05:29 PM |
Hi, yes i have tried loosely fitting and aligning the collector but can only get three of the pipes to kind of fit. The big problem is that i am
having a cat welded onto the collector and dont really fancy belting that with a hammer to get it all to fit. With three pipes loosely on i can just
get the forth to go on about 5mm but when i try to tighten the bolts into the alloy head of the zetec everything goes FT long before there could be a
seal between the manifold and the head. Other point is that with the alloy head do you really want to force the exhaust on???? Anyone have any ideas
on where i can get another to fit?? Have thought about the wetsfield manifold but not sure if this will fit the chassis????
