tiger.avon
posted on 10/6/04 at 09:20 PM |
avon pedals
can any body send me some pics or info
ref pedal modification to the clutch/brake
pedles from the sierra pedle box
i put me clutch cable in and the pedel was way to high. im so close to trying the car
there light at the end of the tunnel but at the mo its a small dot. many thanks
DARRYL
| posted on 10/6/04 at 09:39 PM |
Have you cut n shut the pedals. The clutch and brake pedals need cutting and rewelding, so that they are almost straight, not curved at all. I
don't have any photos
Avoneer
| posted on 10/6/04 at 10:10 PM |
If you cut off just below the wider bit at the top and cut the bit of the bottom that the rubber goes round and then insert a length of 1" box
section - that works and the spacing ends up spot on.
There's a pic somewhere on my website:
www.mytigeravon.co.uk
Pat...
DaveFJ
| posted on 11/6/04 at 08:34 AM |
Yep - I did the same - cut off and inserted some 1" square erw
will try to get a piccy tonight to post
Dave
Avoneer
| posted on 11/6/04 at 05:45 PM |
Pic:
